1988 Chrysler Le Baron car will not start, does not click o
1988 CHRYSLER LE BARON
102,000 MILES • 4 CYL • FWD • AUTOMATIC
DLBWVPHS
car always started good. parked car and would not start 15 minutes later. Battery is new, new starter, neutral safety switch, starter relay, starter switch on column. Checked fuses and fuse links.
Oct 27, 2009 at 6:34 PM
BMRFIXIT
  • 19,053 POSTS
Start your checking at the ignition switch and work you way
Yellow wire should have power with key in start position if not replace ignition switch and retest
starter relay located left shock housing
Oct 28, 2009 at 8:19 PM
