1988 Chrysler Le Baron
1988 CHRYSLER LE BARON
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
CBOLES1964
my steroe went out along with the gpa that tells you your gas mileage anindow. all three went out the same time what could cause this.
May 30, 2008 at 12:03 AM
LEGITIMATE007
  • 5,121 POSTS
well sometimes several things can be on the same ground , so when one goes out it will cause the others to malfunction. and two , it can be a simple fuse, youll have to check them . same thing, one fuse can control several electronics if it blows, all of those electronics on that fuse will not work.
May 30, 2008 at 12:17 AM
