my steroe went out along with the gpa that tells you your gas mileage anindow. all three went out the same time what could cause this.
May 30, 2008 at 12:03 AM
LEGITIMATE007
CERTIFIED EXPERT
well sometimes several things can be on the same ground , so when one goes out it will cause the others to malfunction. and two , it can be a simple fuse, youll have to check them . same thing, one fuse can control several electronics if it blows, all of those electronics on that fuse will not work.
