1987 Lebaron thumping noise on acceloration
1987 CHRYSLER LE BARON
VANLIERDECHAD
I have a 1987 chrysler le Baron 2.2L turbo charged that makes a noise that almost sounds like a flat tire or a knocking sound. It makes the noise intermitently but when it is making the noise the car is accelorating you can also hear it when I let off the gas and the car is slowing down. I just got both of the CV half shaft assemblies replaced because I had one pull out The noise started when the the driver side cv half shaft pulled out. It doesn't seem to interfer with the steering. When the cv half shaft pulled out it made the noise I am refering to and started to shake and pull to the drivers side which interfered with the steering.
Apr 19, 2007 at 10:20 PM
MYERSBUCK
  • 22 POSTS
U joint?
Apr 22, 2007 at 1:55 AM
VANLIERDECHAD
I don't have a U joint its fwd I took it to a chrysler dealer and thay said thay cant find anything wrong. Thay think its the transmission what do you think?
Apr 24, 2007 at 1:46 AM
MYERSBUCK
  • 22 POSTS
hmm well I just had a similar problem (noise with my dodge ram 1500 4x4) As I went down the road it would clunk and it was my U joint, axle, and track bar.
Apr 24, 2007 at 9:29 AM
VANLIERDECHAD
I don't know.... I had the track bar just replaced last year so I doubt thats it. Both CV half shaft axiles were replaced just last week and the car is front wheel drive so we don't have u joints.
Apr 24, 2007 at 9:55 AM
SEANJOHN
  • 4 POSTS
maybe you have a dingy in your booty?
Jun 27, 2007 at 4:11 PM
SEANJOHN
  • 4 POSTS
if the cv joint pulled out while diving theres a good chance its suffered damage. your differential is probably starting to fail and needs to be rebuilt or replaced.
Jun 27, 2007 at 4:17 PM
SLOFING
  • 21 POSTS
The drivers side shaft is held to the side gear with a spring c-clip, if the support bearing that the shaft slides into (and i'm betting on this) has a rough ball bearing it will pop the shaft out again. It is not to difficult to replace the output shaft bearing and available aftermarket
Jul 28, 2007 at 11:58 PM
