1987 Chrysler Le Baron
1987 CHRYSLER LE BARON
16,000 MILES • 4 CYL • FWD • AUTOMATIC
OLLIVIJ
engine is 2.2litre, power light has been coming on lately, car sluggish to pick up speed from stop, timing belt changed about two years ago, friend told me belt could be a couple degrees off, is this possible solution to problem.sometimes when starting engine, idles very rough and if step on accelerator nothing happens, just keeps idling rough
Sep 8, 2008 at 9:39 PM
Hi:
It is possible to be a slight bit off when replacing the timing belt and have the car still run. And yes, it won't run the way it should. However, if you had the belt replaced and the problem is new, I doubt it's the belt.
If you hit the gas and at times nothing happens, I would think you have a sensor problem. Is the check engine light coming on? If so, have it checked for codes. Where I live, Auto Zone will do it free of charge.
Oct 4, 2008 at 11:31 PM
