1986 Chrysler Le Baron CVC Joints
1986 CHRYSLER LE BARON
KEN2007
Drive Train Axles Bearings problem
1986 Chrysler Le Baron 4 cyl Four Wheel Drive 157000 miles
How do you diagnose or recognize problems with the CVC joinst on this vehicle?
Oct 26, 2008 at 5:01 PM
Hi:
The most common way to check a CV joint is to simply turn the steering wheel all the way left or right. Allow the car to drive in a circle. If you have a bad joint, you will hear a clicking sound from the front. Keep in mind, this doesn't have anything to do with a bad CV boot. However a bad boot will eventually lead to a bad joint.
I hope this helps.
Oct 27, 2008 at 1:48 PM
