This is a weird one. All techs at Chrysler dealership stumped!! No start, has fuel, spark, verified valve timing,
replaced pickup plate, injectors, power module, logic module. Good fuel pressure, good injector pulse and plenty of fuel. This is the weird part, will run with throttle body cleaner sprayed down the throttle body??
Used propane in pcv circuit and runs, remove injector rail with new injectors, plugged holes with old injectors and started with propane and injectors are injecting fuel!!
has plenty of vacuum, good compression. Disconnected
map sensor and no change. While cranking it try's to start but won't. checked egr, looks ok, used old drb ll with super cart and no codes. We are all going nuts with this gem. Any thoughts or ideas would greatly be appreciated. ASE Master, Chrysler,Jeep,Dodge. 1989
Jul 30, 2010 at 12:24 AM
