1992 chrysler Lebaron fuel pump relay
1992 CHRYSLER LASER
JAMESTHOMAS44
Could you please tell me where the fuel pump relay on the 1992 chrysler lebaron is located and if there are any markings or numbers to identify it. And is there a way to check the fuel pump to see if it is faulty ?
Aug 9, 2007 at 10:43 PM
Check under the hood in the power distribution center. I believe the lid will be marked. As far as the fuel pump, if the relay is bad, you can't check the pump until the relay is repaired unless you remove the pump and test it or run power to it from the battery to see if it pumps. We have a video how to which shows how to check pump pressure. Let me know if you need it.
Mar 17, 2009 at 8:07 AM
