this car will start everytime idle for a while and stall out. can rev up but miss's and check engine light will come on and die when back to idle. the hotter the engine the quicker it dies. always flass'es code 11 i have tried a different crank sensor even is there a way to test a crank sensor? if i unplug the sensor the car will not fire up. so it must be getting some type or reading at the computor or can it still be a broken wire or did i just get un lucky and get 2 other bad crank sensors? could the pick up that the sensor reads fall off? i am lost as to why the only code i get is 11 any help would be a great thing. the car smells like its fuel so it must be fireing at wrong time with a bad crank reading im guessing on this car. again any help would be great thanks
Jul 21, 2010 at 11:16 PM
