1995 Chrysler Intrepid Cranks but won't start
1995 CHRYSLER INTREPID
270,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEH59
I have a 1995 Chrysler Intrepid with 230,000 kilometres, a 3.3 litre that will turn over but it has no spark, and will not start. It was previously running fine with no problems whatsoever. I have replaced the coil pack, camshaft and crankshaft sensors, tested the relays and looked for obvious defects in the wiring. Any suggestions?
Jun 12, 2010 at 11:29 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard i
Jun 13, 2010 at 1:09 AM
