1995 Chrysler Intrepid backfire,running rich
1995 CHRYSLER INTREPID
153,000 MILES • 6 CYL • FWD • AUTOMATIC
GARNZY
  • 13 POSTS
will a bad map sensor cause a car to backfire once when starting,also can smell gas after it starts
Sep 9, 2009 at 8:33 AM
Running rich:
Probable causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Sep 9, 2009 at 1:22 PM
