1992 Chrysler Imperial head light switch
1992 CHRYSLER IMPERIAL
TOMMY10319
Electrical problem
1992 Chrysler Imperial Automatic 209000 miles
i am trying to replae the head light switch but i took the wire's out of the plastic case they were in cant find what wire goes to what the reason i took the plasti case off is because the previous owner had somone try to fix it. it had a short and melted the plastic casing . the head light switch has about 5 or 6 prongs on it and all i need to know is what color wire goes to what metal prong
Feb 12, 2008 at 9:43 AM
Hi:
With this switch, I recommend purchasing a replacement plug. The clips will be too close to each other and can short if not properly insulated. Try a salvage yard it will be cheap and you then can follow the color codes of the wires in the plug.
Mar 16, 2009 at 10:14 PM
