1972 Chrysler Imperial Burning Oil
1972 CHRYSLER IMPERIAL
TOMEARLY2
Engine Mechanical problem
1972 Chrysler Imperial V8
I have a Chrysler 318 engine in my boat with about 600 hours on it. It suddenly started burning oil in one bank. I'm thinking a bad valve guide or bad piston oil ring. What tests can I do to determine the problem?
Jul 31, 2009 at 4:52 PM
HMAC300
  • 48,601 POSTS
you could do a compression test and a cyinder leakdown test to see if it's piston rings or valves, but it's probably the valve seals are bad. they used plastic and other compuonds. There are better thing s around like positive valve seals that will probably take care of it.
Sep 16, 2009 at 7:46 PM
