2000 Chrysler Voyager with a 2.4L DOHC 16 valve engine with 155000 miles. Had to replace the timing belt 6 weeks ago, also had it tuned at the same time. Started running rough a week ago, stalls at idle or when taking off from a stop. 1 - 3 cylinders test at 185 compression. cylinder 4 tests at 220. cylinder 4 spark plug well also fills with oil and the plug fouls.
Valve clanking is also present. any help would be appreciated....THX
Aug 10, 2007 at 1:23 PM
