No Compression
CHRYSLER GRAND VOYAGER
BRYNNYBEAGLE
Dear Sir I wonder if you could help I have just replaced the cylinder head gasket on my Chrysler Voyager 1997 which has done 117.000 it is a 2 ltre petrol model.
Having reassembled it there is a lack of compression on 3 cylinders, I suspect this is due to the hydraulic rocker arms, is there a method of releasing the pressure in these as it appears that they are holding the valves open, thanks for any assistance
May 4, 2007 at 4:38 PM
MERLIN2021
  • 17,250 POSTS
is this an overhead cam or not? Is the timing belt on? Does the cam turn? Hydraulic lifters probably isnt the problem.
May 5, 2007 at 3:36 AM
