Kids Playing with windshield Wiper knob now they are not working
CHRYSLER GRAND VOYAGER
HULAMOMMY
My son was turning the windshield wiper knob and may have possibly overturned the knob because the markings were no longer lined up with the wiper settings. Now the windshield wipers will not come on at all, on any setting. The only time the wipers work is when I push the knob to clean the windshield. When I do this, the wipers will wipe the washer fluid off the windshield. Can you help me figure out what might be broken?
Jun 21, 2006 at 10:59 AM
VANDRAGON
  • 298 POSTS
well the switch is broken for sure. but have you tried turning it back past the off position? try doing that but only until it clicks once, then try turning the wipers on. it may not work if the stop tab is broken. other than that it is a dealer part or junkyard part. if you could disconnect the washer motor then you could use tape to hold the washer button down on rainy days. i wish you luck. Vandragon
Jun 23, 2006 at 7:22 AM
PABLO22
I put in a new wiper motor wiper did not work put in a new wiper switch that did not work. everything on the switch works even the washer fluid spray on the glass only the wiper does not work .
Dec 30, 2016 at 1:57 PM (Merged)
95BEAR
  • 11 POSTS
Hardwire the motor to make sure it is not faulty. If it is good then you may want to check the wires and or the new switch.
HMAC300
  • 48,601 POSTS
have it scanned may be a body module problem.
