the central locking,drivers electric adjustable seat dont work, the alarm does,also the radio volume goes to zero when i select drive if you turn volume up and then pull away when it selects 2nd gear volume goes to zero again,it goes to zero when ever you pull away[if you have stopped]is there any fuse or anything i can check before i take it into garage.
Jan 26, 2008 at 5:40 AM
