2004 Chysler Grand Voyager central locking and electric adj
2004 CHRYSLER GRAND VOYAGER
37,000 MILES • 4 CYL • 2WD • AUTOMATIC
NEILROBSON
the central locking,drivers electric adjustable seat dont work, the alarm does,also the radio volume goes to zero when i select drive if you turn volume up and then pull away when it selects 2nd gear volume goes to zero again,it goes to zero when ever you pull away[if you have stopped]is there any fuse or anything i can check before i take it into garage.
Jan 26, 2008 at 5:40 AM
2CARPRO JACK
  • 11,533 POSTS
If the stereo is working the trans, you have a big time short somewhere.A shop is probably a good idea, aside from physically looking at the wiring under the dash for rubbing/shorting
Jan 26, 2008 at 8:11 AM
