1999 Chrysler Grand Voyager antifreeze leaking
1999 CHRYSLER GRAND VOYAGER
MHARAYDA
Engine Cooling problem
1999 Chrysler Grand Voyager V8 Two Wheel Drive 117000 miles
My car is leaking antifreeze only when I start the
car, not any other time, we replace hose, coolant
tank- water pump is about 1year
not sure what problem is?
Feb 20, 2009 at 10:22 AM
THIS IS MIKE
  • 686 POSTS
How much does it leak everytime you start it? You will have to find the source of the leak, it is odd that it only leaks when you start the engine. Use a flash light and locate the leak. The cooling system needs to be under pressure to work properly, so any leak in the system is problematic. Check the hoses that go to the heater core and the upper and lower radiator hoses. The water pump could also be failing even though it has only been a year.
Feb 20, 2009 at 2:13 PM
