1998 Chrysler Grand Voyager Replacing rear brake shoes
1998 CHRYSLER GRAND VOYAGER
175,000 MILES • 6 CYL • FWD • AUTOMATIC
OLLYDANNY
MEMBER
1 POST
FOLLOW
How do I remove the rear drums to access the brake shoes. Do I require a puller or should the drums just come off easily?
Oct 3, 2009 at 7:54 PM
CH112063
CERTIFIED EXPERT
In a nice perfect world, they should slide off. But usually you must back off the adjuster or use brute force to pull them off. The cable could hold them also. The parking brake cable gets stuck. There is a way to lube it after you get the drums off. If you need help let me know. ok olly Joe
