1998 Chrysler Grand Voyager power window
1998 CHRYSLER GRAND VOYAGER
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
KELBRO
driver side window will not go back up
Aug 31, 2008 at 5:44 PM
Hi:
It sounds like the switch or the motor is bad. You will need to remove the door panel and check for power at the motor. If you have power there and it doesn't work, the motor will need replaced.
Oct 8, 2008 at 1:32 PM
