1998 CHRYSLER GRAND VOYAGER
HARTLEY
Electrical problem
6 cyl Two Wheel Drive Automatic
I've got one indicator light working but the left is not ive changed the bulbs what esle could it be?
Sep 17, 2009 at 5:06 AM
BMRFIXIT
  • 19,053 POSTS
If it comes on but will not blink
put 4 way flasher on and compare the two sides front and back
compare left side to right side
all bulbs should be working if not and the bulbs had been replaced suspect bad socket ,short in the wiring harness ,multifunction switch and or BCM ,
start with the socket
Check bulbs front and back
check wiring and socket on not working bulb
Sep 17, 2009 at 5:36 AM
