1997 Chrysler Grand Voyager signal lights
1997 CHRYSLER GRAND VOYAGER
HANNAH
the signals will come on if you play around with the relay switch
Sep 15, 2009 at 7:08 AM
BMRFIXIT
  • 19,053 POSTS
Relays switch ??
do you mean signal switch ,or multifunction switch on the steering
and if so suspect bad switch
Sep 17, 2009 at 5:31 AM
HANNAH
[quote:5f10c2a062="hannah"]1997 Chrysler Grand Voyager
the signals will come on if you play around with the relay switch[/quote:5f10c2a062]
the signial lights won't stay on and if you wiggle the relay switch under the stirring wheel.
Sep 17, 2009 at 9:46 PM
BMRFIXIT
  • 19,053 POSTS
check wiring ,replace replay
make sure all light bulbs are good
Sep 18, 2009 at 5:47 AM
