If you do not have spark to any of the spark plugs, it could be due to a faulty coil pack.
The coil pack is mounted n the intake manifold, just above the thermostat housing. It is where all the spark plug wires connects to. (see diagram)
Over time heat and vibration can cause a coil pack to fail. When that happens you will loose spark to the engine and the engine will not start.
https://youtu.be/1zQQy9noYQ0
Thank you.
Aug 23, 2021 at 1:19 PM
