2005 Chrysler Crossfire noise from lower end of engine
2005 CHRYSLER CROSSFIRE
35,000 MILES • 6 CYL • 2WD • MANUAL
MAZDARX
dealership said they need to replace with a short block....is this a prevalent problem with this particular model. If yes, any suggestions.
Oct 23, 2008 at 4:26 PM
If they want to replace the engine, there must be a problem with the main or rod bearing. This isn't a normal problem with these. They could rebuild the one you have. Was the engine run low on oil?
Mar 16, 2009 at 3:36 PM
