2005 Chrysler Crossfire FUEL FILTER
2005 CHRYSLER CROSSFIRE
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARLSTOKES
hOW DO i CHANGE IT AND WHERE IS IT?
Jul 27, 2010 at 4:51 PM
Service and Repair REMOVAL
https://www.2carpros.com/forum/automotive_pictures/12900_ff_23.jpg
Raise and support the vehicle. Remove the fuel pump splash shield. WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. BEFORE DISCONNECTING ANY FUEL LINES, THIS PRESSURE MUST BE RELEASED. Release the fuel system pressure. NOTE: Place a shop towel around fuel lines to catch any excess fuel during disassembly. Remove the fuel filter/pressure regulator fuel line (1). Remove the fuel rail supply line (3) at the fuel filter/ pressure regulator. Remove the fuel delivery hose. Remove the fuel return hose at the fuel filter/pressure regulator. Remove the clamp retaining screw and remove the fuel filter/pressure regulator. INSTALLATION
Position the fuel filter/pressure regulator into the clamp, install the retaining screw and tighten. Install the following hoses/lines in order: The fuel return hose. The fuel delivery hose. The fuel rail supply line (3). The fuel filter/pressure regulator fuel line (1). Tighten the hoses/lines to the fuel filter/pressure regulator. Install the fuel pump splash shield. Lower the vehicle. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jul 27, 2010 at 10:57 PM
