2004 Chrysler Crossfire Compressor doesn't come on
2004 CHRYSLER CROSSFIRE
33,000 MILES • 6 CYL • 2WD • AUTOMATIC
LITZY1
MEMBER
FOLLOW
The freon and fuses are good. Anyhting else I need to look at. Relay? anything that might stop the compressor from coming on
Thanks
Feb 13, 2008 at 5:18 PM
BMRFIXIT
CERTIFIED EXPERT
[quote:b5dd5e58b0="litzy1"]Air Conditioning problem
2004 Chrysler Crossfire 6 cyl Two Wheel Drive Automatic 33,000 miles
Thanks[/quote:b5dd5e58b0]
you need a scanner to check data and codes
that should help pin point the cause
make sure all fuses and relays are ok
