1987 Chrysler Conquest FUEL PUMP
1987 CHRYSLER CONQUEST
BRANIX87
Engine Performance problem
1987 Chrysler Conquest 4 cyl Two Wheel Drive Manual
how do i remove the tank to get to the fuel punp
Oct 31, 2008 at 9:47 PM
DAVE H
  • 13,384 POSTS
REMOVAL & INSTALLATION
FUEL PUMP
Removal & Installation
Relieve fuel system pressure. Disconnect negative battery cable. Raise and support vehicle. On externally-mounted pumps, clamp hose between fuel tank and pump. Disconnect fuel hoses from fuel pump.
Unplug harness connector from fuel pump. Remove fuel pump bracket-to-body bolts. Remove fuel pump and fuel damper as an assembly. Separate damper from fuel pump.
On internally-mounted pumps, disconnect all fuel and electrical connections at fuel tank. Lower and remove fuel tank. Remove pump from fuel tank.
To install both types of pumps, reverse removal procedure.
Dec 10, 2008 at 12:27 PM
