Installing Oil Pressure Sending unit
CHRYSLER CONCORDE
DEMITCH256
Hi...I have a 2000 Chrysler Concorde 2.7l with 72k miles on it. I've recently been seeing my oil pressure light flickering on and off. I checked the oil level and everything was fine. Had the oil pump pressure tested and it checked out fine. I was later told by a friend of mine, who is a mechanic, that it most likely is "your oil pressure sending unit". Is there any way to check out if it is indeed faulty, and if so, how would I replace it myself.
Thanks very much
DaveM
May 4, 2007 at 7:08 PM
MERLIN2021
  • 17,250 POSTS
It's either the sender or the circuit...A special shapped socket is needed to install and remove them.
May 5, 2007 at 3:49 AM
