Hi bschramm,
Thank you for the donation.
Is your system Manual or Auto HAVC ?
Have you tried to retrieve for trouble codes?
DIAGNOSIS AND TESTING - ERRATIC OPERATION OF HVAC SYSTEM
Erratic operation of the A/C and heater systems including:
"¢ Lack of cold air
"¢ Lack of hot air
"¢ Unrequested mode change (ATC only)
"¢ No control of mode or temperature control or tapping blend door noise
These symptoms may be accompanied by the following Diagnostic Fault Codes (DTC's):
"¢ Blend door feedback
"¢ Blend door stall
"¢ A/C Control Mode door input shorted to battery
"¢ In-car temp sensor failure
"¢ ATC messages not received
"¢ Mode door stall
Check for the presence of DTC's with the DRB III(R). If the symptoms and or DTC's listed above are present, perform the following Repair Procedure:
With the vehicle at room temperature 10 to 27 ° C(50 to 80 ° F), pull the M-1 fuse for five minutes to erase any DTC's. Replace the fuse and start the vehicle to recalibrate the HVAC system. Operate the vehicle and A/C heater system to verify that symptoms and or DTC's are gone. If tapping noise or blend stall/feedback DTC's re-occur, additional diagnosis will be required.
The M-1 fuse is Fuse # 19 (15 A) in underdash fusebox. It is the one circled in Red.
Jun 3, 2010 at 12:33 PM
