2002 Chrysler Concorde Front Brake and Rotor change
2002 CHRYSLER CONCORDE
77,625 MILES • 6 CYL • 2WD • AUTOMATIC
HAYLEYGRACE
Can you tell me if there is any special way to replace the brakes and rotors on this car. I plan on doing it myself and I assume you just take the wheel of and swap the old ones out for the new ones and put the wheel back on. Is there anything about this job that I'm going to run into that may cause me a problem? Any special tools or anything else that may need to come off. Thanks, Elizabeth
Jan 6, 2009 at 2:38 PM
ZACKMAN
  • 4,202 POSTS
No special tools, just your basic automotive tools. You will need (if I remember correctly) 17mm socket for the caliper bolt and 19mm for the caliper bracket bolt. Prepare yourself to have these two brake accessories handy. To loosen your rotor from the hub assembly
https://www.2carpros.com/forum/automotive_pictures/55316_16pb_4.jpg
To apply on your metal-to-metal contact points when replacing the pads.
https://www.2carpros.com/forum/automotive_pictures/55316_05359_3.jpg
Jan 9, 2009 at 1:14 AM
