Clean gasket mating surfaces.
Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal. If removed, install two studs.
Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
Lubricate new heater return tube O-ring with coolant.
Position heater return tube flange over two studs. Install nuts.
Tighten retaining nuts to 53 inch lbs.(6 Nm).
Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
Apr 29, 2009 at 6:07 PM
