white smoke is coming out the exhaust?
2000 CHRYSLER CONCORDE
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAEUCOW
I'm burning oil white smoke is coming out the exhaust. What causes that? head gasket replacement instructions please?
Mar 31, 2009 at 12:49 PM
The most common cause of excessive white smoke from the exhaust is engine coolant entering the combustion chamber. The cause is likely related to a failed head gasket.
Take a look through this link first:
If you find the head gasket is bad, below I attached the directions for the removal and replacement of the cylinder heads. You will first need to remove the valve covers and intake manifold. I included the directions for that as well.
I hope this helps. Let me know if you have other questions.
See pics below.
Aug 1, 2021 at 9:08 PM
