1999 Chrysler Concorde something went wrong
1999 CHRYSLER CONCORDE
WHITEPONY78
Electrical problem
something went wrong with the electric locks and the cabin lighting after i tried to install a custom stereo on my own neither one of them work now can you try and help i looked at the fuses how can i fix this problem?
Apr 1, 2009 at 2:05 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You should disconnect the power supply to the new sound system, and re check all the relevant fuses, use a test light and don't just presume that they are ok, start here.
mark (mhpautos)
Apr 1, 2009 at 8:34 PM
CARADIODOC
  • 34,306 POSTS
Ya hooked your new radio's ground wire to the ground wire in the car's gray plug didn't you?
There's no ground wire in the plugs; that's why they have a ground wire or braided strap bolted to the back of the radio. The black and orange wires are for the dash lights and the tail lights. Voltage on the tail light wire tells the display to dim. The amount of voltage on the dash light wire tells the display how much to dim. By connecting these to the new radio, those circuits become grounded through the antenna cable.
Cut and seal the ends of the orange and black wires, then run a new ground wire for the radio. If the dash lights still don't work, replace the dimmer assembly. It is a complicated, unreliable, unnecessary computer module that COULD be burned out by shorting the circuit to ground.
caradiodoc
Apr 5, 2009 at 4:42 AM
