1999 Chrysler Concorde no heat
1999 CHRYSLER CONCORDE
134,000 MILES • 6 CYL • FWD • AUTOMATIC
CYMBALSMASH
put a new thermostat in and new radiator cap also the heater core hoses are hot and still have no heat and this car has no heater control valve why i dont have heat
Nov 5, 2010 at 11:41 AM
WRENCHTECH
  • 20,761 POSTS
The heat in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Nov 5, 2010 at 11:44 AM
MADDOG_
Where is the blend door actuator located? I have this same exact problem. Thank you.
Dec 24, 2010 at 1:25 AM
WRENCHTECH
  • 20,761 POSTS
Please start a question of your own.
Dec 24, 2010 at 1:27 AM
