1999 Chrysler Concorde lose power when going up grade
1999 CHRYSLER CONCORDE
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MSARAKAITIS
why does my lose power when going up of 6 degrees or more?
Oct 14, 2010 at 7:15 PM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 14, 2010 at 9:22 PM
