1999 Chrysler Concorde car knocks
1999 CHRYSLER CONCORDE
111,000 MILES • 6 CYL • FWD • AUTOMATIC
NEEHNA01
i was on my way home with a half tank a gas an my car started ating as if i was going to run out when i got home i turned the car off and it started right up i check the oil and it was empty so i put some oil in and right after i put the oil in the car started making a loud knock it runs really well still it doesn't over heat no lights are on do you know what kind of problem i could be facing oh and my pcv valve was broken
Oct 9, 2008 at 7:26 PM
Hi:
It's most likely a rod bearing, main bearing, cam bearing... Something was starved for oil and has been damaged. Because I'm not there to hear it, I recommend you allow a mechanic listen to it. He / she will most likely be able to give you an idea of what bearing it is based on it's sound.
If you have any other questions, let me know.
JOe
Oct 17, 2008 at 8:54 PM
