1998 Chrysler Concorde Slight whirring, jet noise from fron
1998 CHRYSLER CONCORDE
SCANAS
Noises problem
1998 Chrysler Concorde 6 cyl 117,00 miles
I bought an extremely well cared for 1998 chrysler concorde from a second owner (last 7 years). Only 2 older ladies have owned it. I have all maint. records. Tires are in great shape. But at all driving times, a not so loud like a jet coming from front end. Makes no difference whether I slow down or brake, but I think it stops at idle, its not very loud so I didn't notice. I want to know if I should be concerned enough to take it in to a mechanic. I bought it for $1200, I think she could have gotten more so I'm just a little bit suspicious. Thanks!
Apr 20, 2010 at 8:38 AM
ERNEST CLARK
  • 1,730 POSTS
If you only here the noise while driving (no matter the speed), then it's a front wheel hub. When the bearings go bad, they sound like a jet engine waiting for take off.
If you here the noise even while sitting still, then it's something on the front of your motor being driven by a drive belt. Probably a power steering pump.
You did get a good deal on you car (I owned two), but not a terribly good deal to the point you should be suspicious. After all, it is a twelve year old car.
Apr 27, 2010 at 9:43 PM
SCANAS
Thank you! I'm going to take it in and have it checked out, now I feel armed with a little more information... that is exactly where its coming from too is the wheel. I bought it from a second owner, older single lady who kept all records, really beautifully maintained... now I just have to keep it maintained well too.
May 1, 2010 at 12:33 AM
SCANAS
1998 Chrysler Concord, earlier reply on forum suggested Hub/Bearing (jet engine sound) ... now I am wondering how much to replace/repair? I have 2 recommendations from trusted people for a mechanic here locally. Does it have to be a specialty mechanic? Can a "backyard" mechanic do the job?
May 1, 2010 at 9:44 AM
ERNEST CLARK
  • 1,730 POSTS
Yes you can use a backyard mechanic. he procedure isn't really that hard.
May 11, 2010 at 10:19 AM
