1997 Chrysler Concorde Misfire Detected
1997 CHRYSLER CONCORDE
181,296 MILES • 6 CYL • FWD • AUTOMATIC
TSHEHAN
I have a 1997 Chrysler Conorde what idles low and has a cylinder misfire detected- Cylinder # 5. I have replaced the EGR value about four weeks ago. - Because I received that code and than about two weeks later I keep getting the misfire detected... I have replaced the Spark plugs, wires, and coil. After two to three days the code will come up again. What I'm I missing…
Feb 22, 2009 at 9:34 PM
ZACKMAN
  • 4,202 POSTS
Give the actual code numbers that you receive from the scan tool. In the mean time, here is the diagnostic for engine misfire.
https://www.2carpros.com/forum/automotive_pictures/55316_97concordetc107a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97concordetc107a2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97concordetc107a3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97concordetc107a4_1.jpg
Feb 22, 2009 at 11:55 PM
TSHEHAN
The Code is P0305..
Thanks
Feb 23, 2009 at 9:15 PM
ZACKMAN
  • 4,202 POSTS
The diagnostic works for P0300 through P0306. I kind of figured the code was P0305, for cylinder 5. So perform the diagnostic, concentrating on cylinder 5.
Feb 23, 2009 at 9:18 PM
  • 6 POSTS
[quote:93d6cae11f="tshehan"]Engine Mechanical problem
1997 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 181296 miles
I have a 1997 Chrysler Conorde what idles low and has a cylinder misfire detected- Cylinder # 5. I have replaced the EGR value about four weeks ago. - Because I received that code and than about two weeks later I keep getting the misfire detected... I have replaced the Spark plugs, wires, and coil. After two to three days the code will come up again. What I'm I missing…[/quote:93d6cae11f]
I have the exact same problem. 70,000 miles. Replaced all above. No luck. ??????
Mar 3, 2009 at 6:16 PM
ZACKMAN
  • 4,202 POSTS
Have you followed the diagnostic steps?
Mar 3, 2009 at 9:54 PM
  • 6 POSTS
[quote:f90e416a76="Zackman"]Have you followed the diagnostic steps?[/quote:f90e416a76]
Thank you for your response Zackman. Actually, my mechanic has done the following...replaced the wires, plugs, injector, and tested compression. The engine light stays on and the engine idle is rough, although plenty of power with smooth acceleration. I am assuming both the engine light and rough idle are related, which may not be the case. I am also assuming P0305 is the trouble code as he indicated #5 was the issue. The diagnostic steps above are out of my competence since I lack the equipment although I was once a fair wrench. One thing I did notice is that the idle smoothed and the light went out when I filled the tank full with fuel. This happened two times. The rough idle and light returned when the fuel indicator reached the half way mark. I am thinking of having the fuel filter changed. My mechanic is thinking an intake manifold check. Again, thank you for your suggestions.
Mar 4, 2009 at 5:21 AM
ZACKMAN
  • 4,202 POSTS
Tell your mechanic, before he performs the intake manifold, replace the fuel filter and check fuel pressure at the rail at the fuel rail.
Mar 4, 2009 at 9:13 PM
  • 6 POSTS
[quote:833692fc84="Zackman"]Tell your mechanic, before he performs the intake manifold, replace the fuel filter and check fuel pressure at the rail at the fuel rail.[/quote:833692fc84]
Yup, sounds good. Thanks.
Mar 5, 2009 at 8:45 PM
ZACKMAN
  • 4,202 POSTS
Sure thing...
Mar 5, 2009 at 9:32 PM
  • 6 POSTS
[quote:df2b92326f="Zackman"]Sure thing...[/quote:df2b92326f]
I want to replace the fuel filter on my own. Will removing the fuel cap be enough to release the fuel pressure so I can replace the filter?
Mar 11, 2009 at 5:33 PM
ZACKMAN
  • 4,202 POSTS
Gas cap removal is OK to release the tank pressure but not enough to remove the pressure in the line. Here is the instruction.
https://www.2carpros.com/forum/automotive_pictures/55316_97concordefp_1.jpg
Mar 11, 2009 at 8:19 PM
  • 6 POSTS
Okay. Thank you very much. I do appreciate your help.
Mar 12, 2009 at 6:40 AM
ZACKMAN
  • 4,202 POSTS
No problemo..
Mar 12, 2009 at 10:45 AM
