1997 Chrysler Concorde coolant boils over,and running hot
1997 CHRYSLER CONCORDE
120,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGWILL74
my coolant boils over in the coolant tank.I change the thermostat and i see no leaks around the coolant hoses.but it's still runs hot,and there is no leak present around the water pump.
Oct 6, 2008 at 5:36 PM
Hi:
Most likely, the rad is plugged and not allowing the coolant to circulate properly. Have it flushed and I recommend replacing the upper and lower hoses at the same tim.
Oct 7, 2008 at 10:32 AM
