1996 Chrysler Concorde Ignition
1996 CHRYSLER CONCORDE
152,000 MILES • V8 • 2WD • AUTOMATIC
JEREDDRAKE
I have a 1996 Chrysler Concorde LXI which will not start. I had just driven about 30 miles, then parked the car and went inside to sleep. No problems, nothing unusual. The next morning however, the car would not start. The key turns over and the ignition cranks, but beyond that the car doesn't even sputter. I already replaced the coil pack, but the problem seems fuel-related to me anyway... Any idea what the problem might be? Please be thorough...
Jul 2, 2010 at 12:03 PM
RICHZOMBIE
  • 173 POSTS
I would suggest taking your vehicle to a local parts store and letting them check for bad codes and having someone check to see if you are getting spark when it's cranking but not starting. If you are not getting spark and you get a code 11, since you already replaced the coil pack, then the problem would more than likely be the crank sensor or the cam sensor.
Jul 2, 2010 at 4:08 PM
