1995 Chrysler Concorde turn signals
1995 CHRYSLER CONCORDE
150,000 MILES • 6 CYL • FWD • AUTOMATIC
PATSFAN48
where do I locate the turn signal relay or relays to replace... Are there 1 or 2 relays and which one operates the turn signals and four way flashers ?...
Thank you
Brian
Dec 5, 2009 at 8:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you have 1 flasher called the combination flasher relay which runs both the signals as well as the hazard lights. it can be found behind the dash, between the junction block and the brake pedal.
Dec 9, 2009 at 7:10 PM
