1995 Chrysler Concorde rack and pinion
1995 CHRYSLER CONCORDE
MIZZC2U
Steering problem
1995 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 100k miles
tie rod bolt snapped off in rack and pinion. trying to figure out how to detach rack and pinion from steering column to drill bolt out or replace rack
Dec 30, 2009 at 3:17 PM
CARADIODOC
  • 34,306 POSTS
Getting at that pinch bolt is the hardest part of the job. Why did the bolt snap off? If it was previously cross-threaded, just replace the assembly, but if it was hit, as in a crash, you can try using wire to hold a nut over the bolt, then filling it in with a wire-feed welder. Then you can turn the nut to remove the bolt end. The threads should not be real tight. That trick might save you the trouble of removing the rack.
caradiodoc
Jan 1, 2010 at 4:10 AM
