1994 Chrysler Concorde Air Conditioning stops working when
1994 CHRYSLER CONCORDE
94CONCORDE6CC
Air Conditioning problem
1994 Chrysler Concorde 6 cyl Front Wheel Drive 125,00 miles
The air conditioner works fine when outdoor temps are under 80 degrees (approx.) Once outdoor temps go over 80 degrees the air shuts down.
Thank you very much for taking the time to review this problem.
May 15, 2008 at 2:00 AM
2CARPRO JACK
  • 11,533 POSTS
Need to know the line pressures when the ambient temp is above 80. Might have too much in the system and the pressures go too high when it is that hot out. Does the fan work whent he a/c is on (engine cooling fans)?
May 15, 2008 at 7:51 AM
94CONCORDE6CC
The fan runs fine at all temps, even when a/c stops cooling. I will have the line pressure checked and get back to you with results.
Thank you!!
May 15, 2008 at 2:25 PM
