loses power
CHRYSLER CIRRUS
SANDY2
I have a 1998 chrysler cirrus with 173,000 and after it gets warmed up it loses all power and stalls will start again in 2-5 min and go for a mile or 2 and does the same thing what could be the cause of this. thanks for any help
Mar 21, 2006 at 8:50 PM
VANDRAGON
  • 298 POSTS
i'm thinking fuel pump but could be a sensor. check around and ask lots of questions. get is scanned for codes. they sell an Actron scanner at amazon.com which will be worth its weight in gold if you are going to keep the car and repair it yourself......happy motoring......vandragon
Mar 22, 2006 at 7:06 AM
THEO1973
Hi Sandy ! I've got the same problem.I've changed the fuel pump but,nothing changed.I took it for a diagnostic -did not find anything.Sandy I've noticed that my back exhaust box is extremily hot.And also then the engine is running for a while I meen when the car is running normally and I open the hood,the heat into the engine compartmen is very high aswell.I hardly can keep my hands on the front metal pannel.Did you noticed that on your car.Or it is not the same.Thanks.Theo
Jul 12, 2007 at 4:53 AM
