I have no spark to the cylinder heads and there is no power to the distributor itself whatsoever when checked with a test light. The timing belt is in-tact and the rotor is rotating properly. All the relays relating to the ignition system have been tested and are functioning to specification. What else could it be? Is a faulty ignition switch capable of causing these symptoms?
Oct 10, 2008 at 12:12 AM
