1999 Chrysler Cirrus Big A/C Leak From Radiator?
1999 CHRYSLER CIRRUS
23,000 MILES • 6 CYL • FWD • AUTOMATIC
PLANET_ROB
Hi all. I have an A/C refrigerant leak that seems to be spraying from under the radiator on the driver-side.
In looking at the radiator, it looks as if there are two fairly large radiators sandwiched together, along with a very small one on the grill side of both of them.
Are there refrigerant tubes going to a radiator in front of the car and if so, where on the driver-side could a leak occur? In looking over there, I don't seem to see any joining pipes. All I thought I saw was tranny fluid lines coming in on that side.
EDIT: I went out there and yes, there are tubes coming from my A/C system going to the radiator(s), BUT they go in on the passenger side.
Any ideas? The leak is bad enough that it misted out when I tried to put in refrigerant.
Thanks in advance.........rob
Aug 10, 2010 at 8:42 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
What you are looking at is the A/C condenser, it sits in front of the radiator, i would say it has developed a crack, this will have to be replaced.
mark (mhpautos)
Aug 11, 2010 at 4:49 AM
PLANET_ROB
Thanks!
I can't really see in there. Can this condenser be taken off by itself? I know I may have to pull the radiator, but does this little condenser have fittings so I can take just it off and replace just it? Also, is the second big radiator for the tranny? Seems odd that it would need that much cooling. I've never owned a car that had a huge radiator for the tran.
Aug 11, 2010 at 1:16 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The smaller cooler will be for the transmission oil, it may be an after market add on cooler, the condenser will come out independently, but as i live in Australia i don't see these cars so i have no first hands knowledge, but i can find more info if you need.
mark (mhpautos)
Aug 11, 2010 at 5:17 PM
