Hi all. I have an A/C refrigerant leak that seems to be spraying from under the radiator on the driver-side.
In looking at the radiator, it looks as if there are two fairly large radiators sandwiched together, along with a very small one on the grill side of both of them.
Are there refrigerant tubes going to a radiator in front of the car and if so, where on the driver-side could a leak occur? In looking over there, I don't seem to see any joining pipes. All I thought I saw was tranny fluid lines coming in on that side.
EDIT: I went out there and yes, there are tubes coming from my A/C system going to the radiator(s), BUT they go in on the passenger side.
Any ideas? The leak is bad enough that it misted out when I tried to put in refrigerant.
Thanks in advance.........rob
Aug 10, 2010 at 8:42 PM
