1998 Chrysler Cirrus not getting gas
1998 CHRYSLER CIRRUS
12,400 MILES • 6 CYL • FWD • AUTOMATIC
GRITZSCHKE
Have put in fuel filter and fuel pump. Still not getting any gas .What more could I check without a computer check?
Jul 30, 2009 at 12:47 PM
CARADIODOC
  • 34,306 POSTS
Except for the diesel trucks, you will never solve a running problem on a Chrysler product by replacing the fuel filter.
The most common thing on your car is the crankshaft position sensor on the back of the transmission bell housing. When it fails, which they commonly do when they get warm, the engine computer interprets the loss of signal as the engine stopped running. Then the computer turns off the Automatic Shutdown (ASD) relay which turns off the injectors, coil(s), and fuel pump. You should still hear the pump run for two seconds when you turn on the ignition switch, but it will no longer run when the engine is rotating, (cranking or running).
caradiodoc
Aug 3, 2009 at 4:27 PM
