1998 Chrysler Cirrus How to change the Alternator 1998 Chry
1998 CHRYSLER CIRRUS
178,000 MILES • 6 CYL • FWD • AUTOMATIC
OKCBROTHA
While my car is running or not the car light dims anytime I do something such as unlock the doors. The little battery light comes on sometimes but other times it doesnt. I believe it's the alternator but I'm not sure how to change it. Any help will be much appreciated.
Also I took it to Adavance to see if it's the battery or Alternator and he said that the low batter out put shouldn't even crank the car, but I have never had a problem starting the car it cranks right up.
Jul 18, 2010 at 2:46 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Do you have a volt meter? if yes check battery voltage across terminals post results. Start car measure voltage should be 14.5V to 15.5V.
Let me know
Thanks for donate
Jul 18, 2010 at 3:05 PM
